Post by DanielSheard on Apr 17, 2007 11:14:04 GMT
I've been finding recently that the banner of google adverts often appears in the middle of a post, obliterating the text and there does not seem to be any way of moving or closing it. For example, Phil's first post on water pumps is missing the bottom couple of paragraphs for me.
I use Firefox to browse - dont know if that is an issue or not.
Post by Phil Nottingham on Apr 17, 2007 17:14:46 GMT
Actually I ahve noticed this - annoying is it not?
Post by stantondavies on Apr 18, 2007 7:20:17 GMT
I have no problem Daniel and am using Firefox. try tinkering with your browser settings and/or screen display settings, as these are probably causing this aberration.
Post by johnwp5bcoupe on Apr 18, 2007 18:37:34 GMT
Same problem here it started last week for me same PC same settings
Post by stantondavies on Apr 18, 2007 20:12:07 GMT
Advertisements have started to appear between the first and second posts, presumably to improve visibility and therefore response rate. But they shouldn't impinge on the posts themselves.
Post by DanielSheard on Apr 24, 2007 15:47:01 GMT
Yes, those are the ones. There is a box that they are supposed to appear in. But I find that with the longer first posts the adverts get increasingly out of synch and end up in amongst the text, which you can no longer read.
Post by stantondavies on Apr 28, 2007 7:04:46 GMT
Try resetting your type size.
Post by DanielSheard on May 9, 2007 10:13:41 GMT
The problem has gone away - happened when I updated Firefox although I don't know if that was a coincidence or not.
Post by David on May 9, 2007 11:07:41 GMT
It wasn't me!
Post by johnwp5bcoupe on May 10, 2007 5:46:12 GMT
HMMMMMMM must have been one of them there buggs
Post by stantondavies on May 12, 2007 8:35:33 GMT
It will be the update restoring default settings.
Post by Phil Nottingham on May 12, 2007 8:57:18 GMT
Yes its gone for me as well
