Post by Deleted on Sept 13, 2007 11:49:26 GMT
Has anyone fitted new weather strip to their side windows,is this a difficult proceadure and are there any particular problems to be encountered. any advice would be appreciated.
Post by glennr on Sept 13, 2007 12:11:25 GMT
To clarify,do you mean this trim?
Post by Deleted on Sept 13, 2007 18:43:37 GMT
that's the part!
Post by glennr on Sept 13, 2007 20:09:24 GMT
Very easy to remove. Use something non metallic to avoid damage to the paintwork.Maybe even put some masking tape below the stainless steel part. I used some wood as in the photo on the lower edge then tapped gently upwards and worked along the edge. The clips come of the door easily but be careful not to drop into the door or you'll have to take the door card off to retrieve them. Not sure where to obtain the rubber though as I bought mine with the stainless steel part from David Green. He breaks them for spares.
Post by Warwick (Ozcoupe) on Sept 14, 2007 2:19:38 GMT
Interesting! That's handy to know. I was about to ask this question - or do a search - a week or so ago and decided against it as I tend to get ahead of myself and I'm not yet ready to replace the split rubber on the driver's door.
I expected it to be a long tedious job involving removing the bonnet and rear window.
Doesn't Scott have these listed?
Warwick.
Post by glennr on Sept 14, 2007 7:18:54 GMT
He probably does as he supplies most things rubbery. If in the UK try David Green as he is well into rubber and I am sure he has the parts you require.You can e mail him david@greenp5.fsnet.co.uk
Post by johnwp5bcoupe on Sept 14, 2007 10:09:49 GMT
Yep David stocks them
Post by dorsetflyer on Sept 18, 2007 15:57:19 GMT
Crikey Glenn, I hope DG's other half doesn't look at this site, telling everyone that he's well into rubber. Someone might get the wrong idea. ;D
Post by glennr on Sept 18, 2007 16:16:24 GMT
Yes John, I see what you are saying ;D ;D ;D ;D
