Guus
Post by Guus on Jan 23, 2008 15:16:20 GMT
Hi all, As adviced, I've searched in 'subject' for paint code, and found three 'whites':
DOVER WHITE ICI code for Dover White P030-3274. White 86%, Reduced Yellow Oxide 7%, Reduced Black 7%, (A trace of Reduced Turkey Red Oxide may be required). ICI code for base colours White - P030-9901 Reduced Yellow Oxide - P062-9911 Reduced Black - P062-9929 Reduced Turkey Red Oxide - P062-9915
WHITE (1) ICI code for White(1) P030-3525. White 93%, Reduced Yellow Oxide 4%, Reduced Black 3%. (Traces of Reduced Turkey Red Oxide may be required in White (1). ICI code for base colours White - P030-9901 Reduced Yellow Oxide - P062-9911 Reduced Black - P062-9929 Reduced Turkey Red Oxide - P062-9915
IVORY ICI code for Ivory P030-3427. White 94%, Reduced Yellow Oxide 4%, Reduced Black 1%, Reduced Fast Yellow 1%. ICI code for base colours White - P030-9901 Reduced Yellow Oxide - P062-9911 Reduced Black - P062-9929 Reduced Fast Yellow - P062-9970
But i don't find a description for Rover White though... Is this similar to 'White" as described above? Thanks!
Post by dorsetflyer on Jan 23, 2008 16:55:00 GMT
I may well be corrected on this but I think Rover White applies to much later cars, and from memory, that colour was used on Metros. Unfortunately I no longer have a can that I used on them. James Taylors book on the P5 history should confirm this.
Post by Phil Nottingham on Jan 23, 2008 17:13:33 GMT
Rover White is a P5B colour per JT but its not the same as the later Rover white. I have a full list of mixes somewhere but cannot find it
Post by Deleted on Oct 15, 2008 18:13:01 GMT
hi guys, i know i must sound a total plank, but does anyone know of a good (honest) place in or near London where I can get these mixed up, or even better colour matched to my old girl?
cheers joe
Post by dorsetflyer on Oct 15, 2008 18:42:11 GMT
Getting paints mixed up without matching to the car is very dodgy. Its highly unlikely that you'll get anywhere near the correct colour. You need to go to someone who'll match the paint to the exisitng bodywork which allows for fading and in the case of white, a slight yellowing. Can't help you on finding someone in your area though. Maybe its a thought that these people should be added to the 'Main' Rover site in 'List of Services' as and when we come across them and can recommend them so that others can access their details. I certainly can in my area and most of our local members use him.
Post by Phil Nottingham on Oct 15, 2008 18:57:32 GMT
I agree with DF even if you can get the correct shade mixed up they will have to be tinted to give an exact match and few bodyshops have the knowllege or eye to do this properly.
This was the standard way up to the mid 70's and I still do it to get a better match
