Post by Deleted on Feb 19, 2006 22:24:21 GMT
Hi all I will be changing the gearbox fluid if i remove the drain plug will this empty all the fluid and from the oil cooler
Post by Phil Nottingham on Feb 19, 2006 22:35:48 GMT
Not not unless one of the unions is undone as it will be held by vaccum. It may release if its left standing for several days as like the fluid in the torque converter also, it takes this time to drop below the centre line. Its impossible to fully drain the converter without removing it!
Post by Deleted on Feb 19, 2006 22:52:42 GMT
Thanks phil And one more thing the magnet in the sump were is it ment to be
Post by Phil Nottingham on Feb 20, 2006 8:56:04 GMT
Its often on the bottom or side of the sump pan but it can also be on steel parts of the gear trains etc
Post by PatMcCoy on Apr 1, 2006 20:09:42 GMT
Having a problem Engine rebuilt and gearbox had new pan gasket and front and rear oil seals repalced Left grill and rad off as i am doing other work on it at the moment Not a drop of oil in the 8 weeks it sat there untill last week There seems to be gearbox oil on the floor from the oil cooler pipes Cant see how as it aint been started or moved in 8 weeks? But i remembered a post a while back about this happening to some one but cant find it
Post by roedmose on Apr 5, 2006 19:03:06 GMT
You migth be referring to an entry I made way down in a posting under "gearbox leaking" . I had a leak that meant that the car could stand for quite some time and the suddenly spill a fair amount of oil. And then it could stand again for a while and the spill again.. - I took off the pan and replaced the gasket and I also replaced the small seal at the selector-arm. This little seal was very difficult to reinstall with the box in situ, so take care. In the P6 workshop manual there is a notice that leaks at that little seal is common, and it will appear as though the pan-gasket is leaking because the fluid will sipple down to the pan. - Mine seems to have stopped leaking after these corrections...
Frank
