Post by Deleted on Feb 20, 2006 16:11:44 GMT
Does anyone recommend the Weber conversion and if the kickdown connexion works properly?
Post by Phil Nottingham on Feb 20, 2006 22:18:09 GMT
Whats wrong with the good old SU's?
Post by Deleted on Feb 21, 2006 8:49:58 GMT
The reasonthat I asked is due to this link. www.rpiv8.com/carbs-1.htmI think that any fuel economy is worth looking at. I would also like to explore better performance.
taz
Post by taz on Feb 21, 2006 11:42:11 GMT
In Des Hammill's new book "how to power tune rover V8 engine", he says the SU's are extremely good carburettors and will give within %5 to %7 of the performance of a Weber or Dellorto at lower cost.
Post by Deleted on Feb 21, 2006 14:44:56 GMT
Yeh but yeh, The SUs are single choke (x2)and a bit dated while the Weber is four choke. It also has a built in AED (choke) They dont need tuning either as they have fixed jets.
Post by PatMcCoy on Feb 22, 2006 13:15:17 GMT
I put a weber on last year Easier to set up,Has more power But you must check bonnet clearance And i had to get a electric fuel pump But kickdown has not worked since There is two auto linkages for the the kickdown,But the one i have is useless, Its a brass colour The silver colour one is the right bit of kit www.djev8.com/Its about £60.00 I will look at that when i sort out my servo
Post by Smallfry on Feb 23, 2006 18:53:04 GMT
Its a lot of money to spend for very little gain. £600 or so buys a lot of petrol at one or two mpg saving.
Dont forget to tell your insurance company. I did with my Land Rover V8, any savings in fuel were wiped out by the premium increase.
Another thing is that its noisier, and any perfomance increase is negligable, AND........my kickdown never worked properly either.
If you need new carbs then fine, but on reflection I would have the Su's sorted, or maybe put on a couple of bigger ones.
Whatever you decide, it needs to have a session on a rolling road to get the best out of it.
Post by Geoff Arthur on Feb 23, 2006 21:14:45 GMT
At the risk of confusing matters further, I converted my P5B Coupe to a Holly around 5 years ago. I was previously somewhat sceptical but it transformed the car. It is smoother, much quicker and more economical unless you use the full power increase too much. I like theSUs as well and they are both simple and reliable but it is fair to say that uprated carbs can release more from the engine. My insurance company were not concerned and did not increase my premium.
Post by PatMcCoy on Feb 23, 2006 21:17:51 GMT
Its more than £600 More like £800 with kit down kit and fuel pump I did it because my su's were knackard And to have them refurbed was a lot of money I bought mine secondhand I told my insurance company and they never charged me more And as Smallfry says it needs to go on a rolling road to be setup A m8 has just had his on a rolling road Before 65bhp After 160bhp Price £175.00
Post by stusax on Sept 28, 2006 12:51:02 GMT
I'm about to put a single carb on my P5B, on gas. I've found 3 sorts of manifold that will fit; Edlebrock, Offenhauser and orginal Buick/Oldsmobile type. Any comments about the 3 different kinds? It seems that the Edelbrock is the most popular...
Stuart
