BW 35
Feb 24, 2006 19:25:20 GMT
Post by Deleted on Feb 24, 2006 19:25:20 GMT
HI all i have just replaced my sump gaskit on my p5b gearbox and two of the bolts will not tighten up i think the threads have gone is there any one that can help
BW 35
Feb 24, 2006 19:37:10 GMT
Post by Phil Nottingham on Feb 24, 2006 19:37:10 GMT
Ensure the setscrews have good threads and then wrap one turn of masking tape round -this may work. They do not need to be too tight anyway
As a last resort try a course 6mm self tapping type set screw used on modern car wings.
I do not think the flange is wide enough to take a larger diameter screw or helicoil and doubt that using metal putty will work as its virtually impossible to clean away oil residues
BW 35
Feb 24, 2006 19:45:18 GMT
Post by Deleted on Feb 24, 2006 19:45:18 GMT
Thanks phil i will go and try it now
BW 35
Mar 6, 2006 19:22:46 GMT
Post by lagain on Mar 6, 2006 19:22:46 GMT
I think you should be able to put a thin bolt through. If I remember they should only be done up to 8 lb.ft which is not very tight. Otherwise the gasket will spread. Only use TQF fluid, readilly available in Halfords.
