Post by Deleted on Mar 5, 2006 20:17:16 GMT
after driving for 45mins my car started to pull to the left and then i lost all brakes.when the car stopped with smoke coming from disc and the pedal going to the floor.i checked the brakes today and found no leaks or damage to pads or disc and they now work fine after a short run.has anybody had this problem or an answer?
Post by Deleted on Mar 5, 2006 20:42:12 GMT
WHAT HAS HAPPENED THE CALIPER IS STICKING AND OVERHEATING THE BRAKES THE REASON FOR BRAKE FADE IS YOU HAVE OVERHEATED THE BRAKE FLUID SO YOU WILL NEED TO BLEED THEM.NOW THEY HAVE COOLED DOWN ALL SEEMS OK AGAIN BUT YOU NEED TO LOOK INTO THE PROBLEM TO STOP IT HAPPENING AGAIN
Post by stantondavies on Mar 6, 2006 8:55:12 GMT
I agree with this diagnosis. The situation is similar to brake fade going down mountain passes.
Sort out BOTH caliipers - the one that's sticking AND the opposite side to ensure both in working order and balanced - and bleed the brakes using new fluid. You can use a higher performance fluid eg DOT5 instead of DOT4 which has a higher boiling temperature.
Post by DanielSheard on Mar 6, 2006 10:51:53 GMT
The other thing it might be is the flexible hoses to the calipers. Whilst you are investigating and have to bleed the system anyway, change them - they're cheap.
Daniel
Post by Phil Nottingham on Mar 6, 2006 17:16:45 GMT
I agree with all the comments
I too have had this problem in the past on various P5's and whilst cleaning up the calipers has provised a short term solution I have ended up reconditioning them properly.
These cars cars are heavy and single circuit - do not take chances with safety
Try Serach on both old (if still on) and this site for more info
Post by lagain on Mar 6, 2006 19:16:20 GMT
You should also check the rear cylinders, as these are far more likely to stick than the front, but with those massive springs inside the drums you can get away with it for longer. After a run put your hand on each wheel in turn they should be warm, not hot. Also , if the car is garaged, try pushing it on a level floor. If it will not move either the brakes are stuck or you need to get to the gym !!! While you are at it remember the servo and master cylinder, as you do not want to keep bleeding them.
Post by Deleted on Mar 6, 2006 20:18:54 GMT
thanks alot for all your help,i will have another look and clean up.
