Post by PatMcCoy on Aug 26, 2006 20:14:20 GMT
I think this is the worst job Ive ever done on a car It took me a day to get drivers side off and replace it,with a new greased and wrapped in denso tape and making some gators and fitting a shock Then took me 2 days to do the same on other side It took longer because the bolt in the bush had seized and i had to cut off with a disc cutter And the exhaust had to come off to get the bolt out for the new shock Must admit car sits nice now no sagging on one side But never again PS There was 2 of us doing it
Post by Phil Nottingham on Aug 26, 2006 20:38:04 GMT
Done that and got the teeshirt
Post by PatMcCoy on Aug 26, 2006 21:00:18 GMT
And before any one starts about Authenticity I bought these two weeks ago from Barry Kent and they still have there tag on, 1969 and part number And have nylon disc's in between the leafs One of the ones i took off the car didn't have these Funny enough that was the side that was sagging
Post by Phil Nottingham on Aug 26, 2006 21:07:19 GMT
The original type are the best and will probably see you out!
Post by lagain on Aug 26, 2006 21:11:37 GMT
While putting 40 year old springs on is probably fine you do need to be a bit careful with old stock. I bough some shock adsorbers some years ago which were dated 1967, older than my car, they were totally useless ! Old stock tyres are probably the most dangerous. A tyre has a life of 10 years if it is on the car or being stored, after that time they cannot take the stress and can literally fall apart.
Post by PatMcCoy on Aug 26, 2006 21:15:29 GMT
He had a few sets He has a lot of gear He in the take five mag And is at rushden about 25 mins off junction 15 m1
Post by Deleted on Aug 27, 2006 13:32:53 GMT
When I changed mine I jacked the car up as high as possible,disconnected the prop shaft -undone the rear brackets then dropped down the whole axle onto the ground-loosened the front bolts (broke the exhaust in two after taking the very rear support off under the rear valance!)-then just rolled the whole thing out from under the car-no problem! However putting It all back was very different-had a scissor jack between chassis and spring,widened it to push the back off the spring far enough to engage with the rear bracket whilst a friend jacked up the whole axle -easy peasy
Post by glennr on Aug 27, 2006 15:30:28 GMT
Any comments on the WEFCO gators you can buy? ? I lilke the look of them but not the price.
Post by lagain on Aug 28, 2006 21:24:06 GMT
Are those the leather ones that are made to measure ? If I remember I paid about £200, and that was years ago. They are certainly a quality item and mine have not deteriorated at all. There is no point having grease nipples put in them, just well grease the springs before you put them on. The last set of springs I put on I took apart first and greased each leaf ! They never squeek
I have always found changing the springs very easy. Certainly only do one at a time. With the rear chassis legs on axel stands to support the body put another pair under the axel to take the stress off the springs, remove the nuts from the 'U' bolts, put a trolly jack under the centre of the spring and put on sufficient pressure to take any stress off the Y bush. Put a long thin rod in the Y bush, lever down and release jack at the same time to drop bush from mounting. Then slide out mounting bolt. (well, they did on mine !) at other end of spring. To fit, reverse procedure and then do other side. Then off to the pub for lunch ;D
Post by glennr on Aug 29, 2006 20:40:49 GMT
Yes they are. Thanks for that, another job on the list.
Post by glennr on Sept 6, 2006 7:12:44 GMT
I need advice on re greasing the rear leaf springs. Will they have to be removed off the car? Couldn't find anything on search.
Post by PatMcCoy on Sept 6, 2006 8:02:29 GMT
With them off the car I took the leafs apart Got a tub of grease and a paint brush Wire brush them ,and paint grease all over the leafs Build them back up again Put back on car,Wrap denso tape on them,them place a gator over them
Post by Phil Nottingham on Sept 6, 2006 18:21:20 GMT
Alternatively use a cold chisel to force the leaves apart and squirt in spray on grease.
There was a special tool to do this very job in the 1930's
Post by glennr on Sept 7, 2006 16:42:11 GMT
Anybody got a special tool that they used in the 1930's? ;D
