Post by Deleted on Nov 8, 2006 19:43:56 GMT
Hi, Confused here in Norfolk.
Recent purchase of a one owner 1968 3.5 saloon has revealed overheating problems. Several avenues of support and advice have opened up, but I am still anxious.
It was visibly evident that the engine was getting too hot by the gray paint on the inlet manifold all cracked and flaking, and on the rocker covers. Removing the rocker covers revealed burnt oil which had carbonised.
We assumed that it was a head gasket blown and was boiling the water and forcing it out which is common on most vehicles with the same ailment. So we examined the radiator and it was clear that it was badly silted up and full of gunge etc., We removed it and it's gone off to be re-cored (3). We took the water pump off and replaced it with the new extra vane type, removed the inlet manifold, cleaned all the gunge and rubbish out of it etc., and are ready to re-assemble evewrything.
HOWEVER !! We were advised to prove or disprove the head gasket
by applying a compression tester to each spark plug hole.
We were told that if a gasket has blown in to the water jacket, the gauge would go up to 150/180 lbs pressure and then start to fall away as it leaked out. We tested each pot and 7 were spot on with no fall in pressure. The 8th one revealed a pressure of 85 lbs only. We were advised to pour some oil down the plug hole and try again. This only made a marginal difference and we were told that means it's probably a pitted or ill fitting valve seat and to fit new tappets and push rods.
These are now on order from JRW.
All this is to try and avoid taking the cylinder heads off with the engine in situ, which we were advised again was a horrible job.
Why we are confused is because it says in the workshop manual that if a compression test reveals a lower reading, it means that the gasket is faulty between the adjacent cylinder
Who is right ?? We were told that head gaskets blowing was rare on these engines ? Should we re-assemble ? or bite the bullet and take the head off ??
Mike
Mike
