Post by kaiuwe on Nov 28, 2006 18:24:51 GMT
Hi, I´ve a question: My power steering box leaks and there is sometimes al loss of power. I think after reading in this forum, I´m going to buy one from wadhams on exchange which seems to be a very good solution for the problem. What else should I change when working on it anyway ? I heard the filter needs replacement from time to time. Maybe any other things ? Seals ? Thanks for your help ! I own the old lady since may this year and still have to learn a lot Kai-Uwe from Germany
Post by Phil Nottingham on Nov 28, 2006 19:07:37 GMT
Leave seals if not leaking but ensure the rubber boots on ALL the ball joints are good.
The filter only needs changing once in a blue moon but definitely when the box is renewed
Post by kaiuwe on Nov 29, 2006 19:25:53 GMT
Many thanks for the quick answer!
Kai-Uwe
Post by glennr on Nov 29, 2006 21:48:26 GMT
I had my steering box replaced and filter. If you opt for a second hand box you are taking a chance. I did it, and the bloody thing leaked like a sieve. I therfore (once again!!) dug deep and bought a replacement unit from Wadhams.
Post by Multi-Tech on Nov 29, 2006 23:34:46 GMT
I took a chance with a 2nd hand box, won it for £20.57 from ebay, fitted it on and result no leaks ;D so you can be lucky just depends if you want the extra hassle having to take it all apart again if it doesn't
Post by Phil Nottingham on Nov 30, 2006 18:52:41 GMT
I usually try that route first - at least it gives some breathing space and one available for exchange
