Post by Deleted on Dec 7, 2006 14:13:50 GMT
:( My P5B saloon developed a bad leak from the steering box in 2005 I bought a new pump and recon box in July 2005, from Roverpart. This was OK for a while then developed the same problem. Heavy leak. Roverpart sent a replacement FOC, but this is also leaking. They have offered to replace, but I will need to pay his expences, which is acceptable.How can I be sure it won't happen again? This time the leak is coming from the breath hole at the front Is their a modification, or any fitting advice? I see that this type of problem has been aired before. Can you help? Please
Post by glennr on Dec 7, 2006 14:44:57 GMT
All I can say is that I bought mine from Wadhams as have many others and I have never heard of a problem with their recon units. Maybe the RoverPart boxes are reconditioned differently. Very sorry to hear of your problems.
Post by Phil Nottingham on Dec 7, 2006 18:21:02 GMT
I have heard of this with other sourced recon boxes but not with any from Wadhams. Bad luck
Post by lagain on Dec 7, 2006 18:35:12 GMT
Is it possible that the pump is creating too much pressure, I have no idea if this can happen, but if you are on a 3rd box that is leaking it could indicate that there is a problem elsewhere. I have dealt with Roverpart for many years and usually their parts are good.
Post by Phil Nottingham on Dec 7, 2006 20:15:53 GMT
As mentioned on another thread recently its always a good idea to change the pump - the pressure valve is well known for failing and can actually split the steering box casings under high pressure situations on full lock standing if it sticks closed instead of open
Post by Deleted on Dec 9, 2006 13:53:18 GMT
Ok Thanks Guys
Post by glennr on Dec 9, 2006 21:58:13 GMT
I replaced the pump and box as advised by this site (cheers Phil) and have no problems. Sure it cost me, but peace of mind prevails and no leaks!!!!
