Post by Deleted on Feb 19, 2007 11:27:02 GMT
When i brake, the front pulls to the left slightly yet when releasing pedal, it veers to the right. If i jack the front, the wheels seem free. Would this sound like a classic case of the hoses being blocked? I am renewing them anyway as they are getting old.
Post by stantondavies on Feb 19, 2007 15:19:52 GMT
Everything wants checking Humphrey. Looks as if the RH calliper isn't working as well as the LH, but it could be hoses or the rear drums. I would go thru' the lot starting at RH calliper.
Post by Deleted on Feb 23, 2007 10:22:44 GMT
Spot on, absolutely spot on. Siezed piston in O/S/F caliper is 2/1 on!
Post by Deleted on Feb 23, 2007 16:12:50 GMT
I just changed the hoses and did a road test. The brakes are now normal. One of them was blocked as I suspected. I thought it was not the pistons as i have had that happen before and you could tell as they would stick on and overheat.
Post by Deleted on Feb 23, 2007 17:16:10 GMT
I owe you money Ironiclly, changed all 3 of mine a couple of weeks ago, because I had them. They were all a bit manky inside. Glad I did!
Post by Deleted on Feb 23, 2007 18:40:03 GMT
You missed the significance of the fact that it veered on RELEASE of the pedal. The blocked pipe was on the right ,meaning that release was delayed.
