Post by eightofthem (Andy) on Apr 16, 2007 20:53:22 GMT
Here is one for you. Anyone know the capacity of the radiator in litres?. I am having some cooling problems, running hot ,top hose hot, bottom hose hot, radiator cold with patchy heat on the sides.I suspect a blocked core (this after it has been inspected and tested by rad specialists) so my thought would be to test how much fluid it holds with what it is supposed to,anyone had the same trouble?.
Post by Phil Nottingham on Apr 16, 2007 21:34:36 GMT
16 pints - its usually a blocked core and sounds like it from what you say - any rad repairer can test this! See earlier thread
Post by stantondavies on Apr 17, 2007 7:23:50 GMT
16 pints seems a lot of water just for the radiator Phil. Are you sure?
Post by Keith - Portsmouth on Apr 17, 2007 9:41:09 GMT
16 pints is the capacity of the complete cooling system.
