Post by park01 on Jul 16, 2007 13:33:59 GMT
Hi All
Their is a arm bolted to the back axle, which the arm for the hand brake rods is connected to. Is the arm which is connect to back axle susposed to move with the operation of the hand brake?
Many thanks Karl
Post by harvey on Jul 16, 2007 14:50:02 GMT
It is supposed to be able to move as it is the compensator which enables equal braking effort to be applied at each wheel.
Post by johnwp5bcoupe on Jul 16, 2007 16:05:01 GMT
If the sliders and rollers are seized on both or one side it will not move best to check
Post by park01 on Jul 17, 2007 17:41:04 GMT
the arm attached to the axle has a rubber bush in the middle with a metal sleeve through it. which the bolt goes through to attach it to the axle.
Post by johnwp5bcoupe on Jul 17, 2007 18:06:46 GMT
Yes the balance lever connects to the long and short cross rods which connect to the draw links which pull the shoes on and off by means of the rollers and tappets
