Post by Deleted on Jul 24, 2007 8:22:10 GMT
What is the function of the little plastic part in the vacuum line between the dizzy and the carb? Can anything go wrong with it?
Post by Phil Nottingham on Jul 24, 2007 18:12:57 GMT
Which part is this?
Post by Deleted on Aug 1, 2007 8:32:18 GMT
It was on the car when I first got it. I never thought about it till recently. It is like a little flame trap with "carb" at one end and "dist" at the other. Made of bakelite.
Post by Warwick (Ozcoupe) on Aug 1, 2007 9:50:36 GMT
Sounds like a restricted check-valve used to slow the application of vacuum advance. (Or vice versa - can't remember which). If you blow through it, it should be much easier in one direction than the other. They have a tendency to block up. The only car I've ever had with one fitted is the Series 2 Peugeot 505 GTI and they generally run better if you pull it off and throw it in the bin. I think it was a pollution control measure applicable to that period. I can't imagine why it would be on P5, but there are wiser heads here to answer that question.
Post by Phil Nottingham on Aug 1, 2007 15:51:03 GMT
Cannot see any reason for this at all either - the vac advance as standard is the best compromise with a electro=mechanical dizzy/ignition and altering would affect fule economy/power/engine durablilty so I would remove it without delay as it probably not working properly anyway
Post by Deleted on Aug 1, 2007 17:00:18 GMT
I will take it out then. I have to fit a new condenser anyway.
