Post by Deleted on Jul 27, 2007 22:51:53 GMT
Hi all fitted range rover v8 engine top end noisey changed tappets and push rods but still noisey engine has good oil preasure cauld it be blocked oil ways to top end
Post by Phil Nottingham on Jul 28, 2007 8:23:16 GMT
You have changed tappets/pushrods? New or secondhand? It can take 20 mins or so to pump them up but once done should stop like it
Was there a lot of black gunge - if so oilways could be blocked but engine is likely to be in a bad state generally
Post by Smallfry on Jul 28, 2007 22:08:04 GMT
Checked that the hollow rocker pedestals sit on the oilways ?
If rocker shafts have been dismantled at some time ?
