Post by Deleted on Jul 29, 2007 9:20:48 GMT
The 3.5 V8 manual advises the use of 3M EC377 thread lubricant to assemble V8, especially cylinder head bolts. Does anyone know where to get some? -- or an equivalent? Thanks
Post by harvey on Jul 29, 2007 11:21:36 GMT
Try Land Rover dealers, they still work on V8's and SHOULD be using it or something similar. Without it head bolts will snap in the block when you try to remove them after any length of time.(I speak from bitter experience, having removed the heads from an engine that had been assembled without it in the past.)
Post by harvey on Jul 29, 2007 11:31:38 GMT
I've just looked at mine (ooh err missus) it was L/R part no. 608591 (about 20 years ago) and it's 3M ScotchClad "776" Fuel Resistant Coating & Adhesive. 1 litre tin.
All the technical specifications for the above are still on the 3M website, so it should still be available, or at the very least 3M should know of another suitable product.
Post by Deleted on Jul 29, 2007 17:20:06 GMT
i was told by paines engine builders to use copper grease
Post by glennr on Jul 29, 2007 17:50:47 GMT
Post by harvey on Jul 29, 2007 18:20:38 GMT
"776" is the 3M ref. and is as I said earlier still listed on their website. I would buy the correct sealant, copper grease dries out and although it may keep bolts free initially I wouldn't use it, particularly on the head bolts. If a job's worth doing it's worth doing properly,and although it will be expensive it's a lot cheaper than removing snapped bolts.
Post by Deleted on Jul 29, 2007 21:42:24 GMT
Thanks for all the suggestions. I have found another manual which has EC776 as the number. I just have to find some of that then!!
Post by johnwp5bcoupe on Jul 30, 2007 6:06:21 GMT
Harvey is right use the correct stuff Copper Grease will dry out it is fine if not heated lasts for years Harvey I have sent a PM.
Post by glennr on Jul 31, 2007 15:37:10 GMT
You can purchase EC776 Scotchclad Fuel Resistant Coating, from the follwing distributor: BDK Industrial (Ipswich) Tel: 01473 659059
