Post by Deleted on Jul 29, 2007 17:56:11 GMT
Hi all will be ok to just change the rocker sharft for a new ones or do i have to change the rockers as well
Post by harvey on Jul 29, 2007 18:23:40 GMT
Worn rockers will just score up the new shaft.Remember that the shafts have to be fitted the correct way around.
Post by Smallfry on Jul 29, 2007 18:23:48 GMT
If the shafts are badly worn, then the rockers will be too. Change them. Make sure you assemble the shafts correctly............there is a notch in the end of the shaft. The manual should tell you the rest. If you get it wrong, the oil holes will be in the wrong position, and will wear out the rockers again fairly quickly.
