Post by Deleted on Aug 8, 2007 16:26:53 GMT
I have a P5B saloon and was planning to fit some wider wheels; ideally some 7x15 inch slot mags. Does anyone know if this size of wheel is likely to cause problems with fouling the bodywork/suspension. Any advice/suggestions much appreciated.
Post by Kev on Aug 9, 2007 18:37:07 GMT
They sound great, you may find they just touch the inner lip on the wheel arch,but i am sure if you want them on bad enough,you will find a way round it.Probably depends on the squareness of the tyre also.What you really want is some 17" wheels with low pro tyres,,,,,,,,,,,oh er. Big Kev.
Post by Deleted on Aug 14, 2007 16:21:34 GMT
I was thinking of 215/65's as this gives an overall diameter similar to the standard; saves having to re-calibrate the speedo as well. I think BFG's would look good if a little dear.
