Post by Deleted on Aug 12, 2007 12:54:00 GMT
Hi all i have got the top part of the engine of and what is the best way of cleaning the oil ways out
Post by dorsetflyer on Aug 12, 2007 19:57:36 GMT
Immerse them and soak them in either petrol or diesel, or a mix of both overnight and blow through them with a high pressure air gun. If not completely clean, repeat the process.
Post by Smallfry on Aug 12, 2007 19:59:17 GMT
When you say oilways.........do you mean the actual drillings in the block, or do you mean the valley where the valve lifters live ? Or are you just talking about the heads ?
If you mean the drillings in the block, you can't safely do it unless the engine is completely stripped, and realistically, its the same for the valley, I can't see how you could do it without being sure of NOT getting any crap left inside.
Take the engine out and do it properly, or I suspect you are going to regret it. Its a shame you are not nearer, or I would help you with it
Post by Deleted on Aug 12, 2007 20:02:12 GMT
Thanks for that do you mean the oil ways that come through the heads is ther any offer oil ways from the heads down
Post by Deleted on Aug 15, 2007 21:40:43 GMT
Thanks smallfry i have got the heads of ,front timeing cover inletmanorfold and sump of there is a lot of hard black oil in there
Post by Phil Nottingham on Aug 15, 2007 21:53:04 GMT
There always is - cleaning the head and oilways is easy, its the stuff that's in the block that causes the problems and disturbing it can be disastrous.
Be very careful if you try to clear this mess out. Short of a rebuild its best to run a few hundred miles using high detergent diesel oil but even this can cause terminal oilway blockages
Post by Deleted on Aug 16, 2007 7:29:21 GMT
With all that hard oil crud, I would take off the inlet manifold and the tray. Inspect the camshaft particularly rhe rear two lobes for wear.
Post by Phil Nottingham on Aug 16, 2007 16:03:22 GMT
I thought that's what he had done?
Post by Deleted on Aug 16, 2007 17:29:12 GMT
Good point. Once should be enough. ;D
Post by Smallfry on Aug 17, 2007 21:29:31 GMT
Well..............They DO wear very quickly !
