piston
Aug 17, 2007 19:26:09 GMT
Post by Deleted on Aug 17, 2007 19:26:09 GMT
Hi all i took one of the heads of today and the top edge of one of the pistons looks like it has melted and on the head has melted i looked at the bore and that is scorded down one side what could have caused this
piston
Aug 17, 2007 19:31:03 GMT
Post by Phil Nottingham on Aug 17, 2007 19:31:03 GMT
Broken piston ring?
Foreign body drawn in eg nut
piston
Aug 17, 2007 20:52:24 GMT
Post by Smallfry on Aug 17, 2007 20:52:24 GMT
Lack of oil...............or changes.
Over lean mixture.
Overheating.
Running without, or damaged air filters.
You are not having much luck with this are you ?
piston
Aug 23, 2007 11:15:12 GMT
Post by Deleted on Aug 23, 2007 11:15:12 GMT
Was that the engine where you fitted a larger/longer oil pump? Probably meant that there was no oil pressure at all.
piston
Aug 23, 2007 21:11:46 GMT
Post by Deleted on Aug 23, 2007 21:11:46 GMT
no that was in my p5b engine the range rover engine i have not done any thing to apart from starting to strip down and found the problem with the piston and the head Now i am going to start on my p5b engine put new bearings in the top end i have done i just need to find out what size bearings i need to get
