Post by Deleted on Aug 27, 2007 10:18:40 GMT
Hi all i have stiped the engine down in the car what is it like to get the engine out but leave the gear box in place and the same puting it back in
Post by johnwp5bcoupe on Aug 27, 2007 11:35:50 GMT
I would take them out together vince I know it can be done both ways there are a few more items to remove taking them out together but it will save a few risks trying to line up the two in the car if you do a search I am sure you will find some info Good Luck.
Post by Deleted on Aug 27, 2007 11:45:44 GMT
Thanks john the only thing is i have not got the room for a engine hoist when i changed the engine before it was at a friends house
Post by Deleted on Aug 27, 2007 11:46:27 GMT
Finding that the gearbox seal has been broken when lining up the engine is just not funny.
Post by Welsh Warlock on Aug 27, 2007 12:42:21 GMT
Vince, you may recall that I took the engine out of my car back in Feb and Decided to leave the gearbox in place.
Bad move!
I am now dealing with the aftermath of that and have the gearbox out having damaged the seal when putting the engine back in. As the box is out I have decided on a rebuild. in fact having discovered that its an early box I'm going to get a later one rebuilt but that's another story.
For what its worth I would highly recommend removing both. Even if you have to remove them seprately but they should b mated up out of the car and reinstalled as a unit.
I didn't and I regret it!
Post by johnwp5bcoupe on Aug 27, 2007 13:03:17 GMT
A lot of good advice given vince on the problems that can happen on my other coupe I had in 1970 ish I tried to change the gearbox alone and it was a pain to do on my own I ended up dropping the sub frame and lifting the body that way I could manage on my own
Post by Phil Nottingham on Aug 27, 2007 14:56:30 GMT
I have always removed mine as one unit - its far easier in the end especially on your own.
Use SEARCH for 500 days
Post by Warwick (Ozcoupe) on Aug 28, 2007 4:53:03 GMT
I have always removed mine as one unit - its far easier in the end especially on your own. Use SEARCH for 500 days What's going on here? Phil's cut his search recommendation back to 500 days. There must be something he doesn't want you to find.
Post by PatMcCoy on Aug 28, 2007 7:32:42 GMT
LOL ;D
Post by Deleted on Aug 28, 2007 13:32:02 GMT
Does LOL mean 'Laugh Out Loud'
Post by PatMcCoy on Aug 28, 2007 18:22:32 GMT
Yes
Post by Phil Nottingham on Aug 28, 2007 19:09:01 GMT
I just do not want to embarrass anyone(s)
