shims
Aug 28, 2007 21:04:37 GMT
Post by Deleted on Aug 28, 2007 21:04:37 GMT
Hi all when i fit my new cam do i need to fit shims under the rocker shaft pedestals to set the preload
shims
Aug 28, 2007 22:12:23 GMT
Post by Phil Nottingham on Aug 28, 2007 22:12:23 GMT
What preload?
Hydraulic tappets are used so no pre-load is required
I would strongly advise you refer to the workshop manual otherwise you may damage some expensive new part
shims
Aug 28, 2007 22:28:55 GMT
Post by harvey on Aug 28, 2007 22:28:55 GMT
Hi all when i fit my new cam do i need to fit shims under the rocker shaft pedestals to set the preload Somebody's been looking at the RPI website. (Don't paint in the valve chest with housepaint by the way, or p155 into the wind..........)
shims
Aug 29, 2007 10:13:24 GMT
Post by Deleted on Aug 29, 2007 10:13:24 GMT
When you say new cam, do you intend to change the followers as well? I hope so as old ones will destroy the cam in minutes.
I also strongly recommend using a jointing compound on the inlet manifold. Any leakage of air here will ruin the emissions.
shims
Aug 29, 2007 10:48:39 GMT
Post by petervdvelde on Aug 29, 2007 10:48:39 GMT
Vince,
You may need to fit shims. I overhauled the SD1 engine in my MGb about 7 years ago and needed some shims. I don't remember the procedure anymore but believe i received some instructions with the new lifters. Will have a look when i am at home if i still have these instructions. Regards Peter
shims
Aug 29, 2007 11:21:34 GMT
Post by harvey on Aug 29, 2007 11:21:34 GMT
All the info is on the RPI site, but as it says on there you may or may not have a problem. What it doesn't say is why the need to check it arises in the first place, as it's not set at the factory, and is not a problem (and never has been) on engines straight out off the line. What does alter things is skimming the heads and recutting the seats and leaving the stem of the valve the incorrect height above the valve spring seat. Both of these move the pushrod down into the follower. The use of composite gaskets has the opposite effect.
shims
Aug 29, 2007 17:04:16 GMT
Post by Deleted on Aug 29, 2007 17:04:16 GMT
when you say use jointing compound is that under gasket and above gasket yes i am fitting new liffters Thanks for all the help
shims
Aug 29, 2007 17:08:54 GMT
Post by harvey on Aug 29, 2007 17:08:54 GMT
Use Hylomar on both sides of the gasket, but only around the waterways.
shims
Sept 1, 2007 21:49:05 GMT
Post by Deleted on Sept 1, 2007 21:49:05 GMT
Its just that I had an air leak on the inlet manifold. That is why I recommend it.
