Post by Deleted on Sept 11, 2007 22:28:09 GMT
My Saloon is a late one - 1973, and it has the automatic enrichment device. What is the correct procedure to start the engine from hot and cold? From cold it says in the handbook - don't touch the throttle, just turn the key. When I do this it almost catches immediately, but then I have to churn the starter for a few seconds before it really goes. When hot it also seems to need some throttle. It always starts in the end but should it be easier? Do I need to get anything investigated?
My previous 3500S (many years ago) had a manual choke which lit a light on the dash when the engine was warm enough. It always started on the button.
Post by Phil Nottingham on Sept 11, 2007 22:38:39 GMT
The AED are notoriously unreliable - you may find a starting procedure that suits it but it may not stop consistent anyway. Your symptons are typical. Even Rover gave up anf offered teh conversion. They cause excessive engine (and starter wear). A worn mechanical petrol pump also causes engine churning - convert to electric.
Mine starts immediately in any weather with choke out when it's cold
Its far better to convert to manual choke kits can be obotained. If you want the warning light you will have fit an Otter" switch in place of the triangular blank plate on the top of the manifold and also obtain teh choke cable switch and orange/yellow console light.
David Green may be able to supply all this secondahnd
Post by Deleted on Sept 12, 2007 16:23:26 GMT
Thanks for the reply Phil. Is it not possible to clean/overhaul the AED - as it's a good thing in theory....
Post by johnwp5bcoupe on Sept 12, 2007 17:21:08 GMT
theroveringmember
Post by theroveringmember on Sept 12, 2007 17:58:30 GMT
While I understand the desire for originality, I can't understand keeping such an abomination as the AED, which as well as being unreliable, uses more fuel & is bad for the engine. It's the first thing that came off ours when she was re-built & I was glad to see the back of it. It was a pain in the ar*e & I wouldn't dream of re-fitting it. Still, thats just me. My friend got the carb parts from a TR7 & an original pull handle from the Rovercentre in Leyton (that's going back some) & his brother made a double length mounting bracket out of brass (along with the other undershelf brackets) so it sits alongside the reserve pull.
Post by johnwp5bcoupe on Sept 12, 2007 19:08:32 GMT
IF the AED is in good condition and set up properly they are no problem the one I have fitted works 100% I have had two P5b's both were the family run abouts in the time when they were newish and I never had a problem could it be age?lack of attention? blocked air flow to the AED? asbestos ( then) gasket gone on the manifold maybe cause
