Post by Deleted on Oct 3, 2007 22:03:14 GMT
can any body tell me the right way to change to electric fuel pump and what do you do were the old one is this is my p5 3.5 with a machanical pump
Post by Phil Nottingham on Oct 3, 2007 22:23:18 GMT
Use SEARCH set for 900 days - there are various options - hope you have got teh correct pump!
The old pump should be removed and blank plate fitted unless you want to "fake" it for originality
Post by johnwp5bcoupe on Oct 4, 2007 5:55:12 GMT
There are several places to fit them this was my solution you can do it from under the car without removing the gearbox tunnel search was not very helpful I have fitted the clamp on the other side hose just so my mate harvey doesn't worry Also done away with the fuse holder and wired to the ancillaries on the block
Post by harvey on Oct 4, 2007 11:50:09 GMT
Glad you put a clip on that pipe John, it was beginning to worry me, hope you've tightened those prop bolts as well!
Post by Deleted on Oct 12, 2007 20:26:07 GMT
does any one know where i can buy an elec pump in manchester for my 3.5
Post by Deleted on Oct 12, 2007 20:27:11 GMT
