Post by Deleted on Oct 15, 2007 20:54:38 GMT
here's another one for you...
you know the heater tap at the back of the engine, that feeds the the heat to the rear passengers (i think that's right from the owner's manual)?
well, it says 'pull for heater'. I CAN'T. it's stuck down. and i've tried to pull quite hard.
any ideas?
ta
Post by johnwp5bcoupe on Oct 15, 2007 21:05:59 GMT
Remove it and soak it in WD40 for a couple of days if that doesn't work get another from David Green
Post by Phil Nottingham on Oct 15, 2007 21:11:09 GMT
Soaking it in Diesel for a couple of weeks may work and carefully trying to trun it with a pair of Mole grips after unscwing the knob.
They cannot be serviced and can leak under pressure.
Avoid this happening again by using it evet month or so
