Allan NZ P5b
1971 p5b Auckland New Zealand
Post by Allan NZ P5b on Apr 22, 2005 2:56:02 GMT
On the saloon they are the same as the mgb dash lamp and here in New Zealand easy to get and alot cheeper than I could source Ex the UK. Thanks anyway David Green for your price. I will be back for other bits. Also got within 2 days, also good. ;D Will put on 4 new lenses and covers tonight. easy job lots of satisfaction ;D as mine were very tatty.
Allan NZ P5b
Post by Allan NZ P5b on Apr 22, 2005 21:38:57 GMT
Not as easy as I thought the new light covers are very slightly different about 0.5mm wider at top courners will have to remove lamps from car and carefully bend base lip. will also make new gaskets to seal to base. Has anybody else had this problem. They appear exactly the same in every other way. Never mind it is allways fun working on car.
Post by Phil Nottingham on Apr 22, 2005 21:49:06 GMT
I always thought they were the same - even the Coupe version only differs with the addition of the rubber spacer
