Post by Deleted on May 5, 2005 10:24:31 GMT
can anybody help please??? I have a intermitent problem with the indicator switch on a 1970 p5b saloon.sometimes it does not indicate at a steady rate but it seems to hesitate and slow down before it resumes to a steady flash.it seems like an earth problem but i do not know where to look, i have had the switch apart but that seems to be o.k. norman
Post by p5tgc on May 5, 2005 12:11:57 GMT
I would recommend you change the indicator flasher unit to a modern type which is not sensitive to voltage.
Check back in the previous postings for the procedure to fit a Mondeo flasher, this worked for me.
Post by Deleted on May 5, 2005 12:23:36 GMT
thanks i will try it and see what happens norman
Post by dorsetflyer on May 5, 2005 16:24:35 GMT
Everyone seems to have trouble with indicators. It probably is an earth problem, and it is a case of starting at the front indicators, then the repeaters, then the rear ones. it's a case of making sure the earth contacts are corrosion free, and if possible a coat of vaseline when cleaned will help. The other day I had the problem where only one side would flash, and the otherside stayed on. I thought that the front bulb had failed, but it hadn't. After removing the bulb a quick spray of WD40 and manually working the contact spring a few times cured the fault. I must admit though I don't have any problem with the speed of flash, they are roughly the same.
Post by adrian50 on May 13, 2005 7:55:29 GMT
We don't all have problems with indicators!! (Now I bet the bu**ers play up!)
It is true that many problems are due to corrosion at bulb holders and terminals etc. Eventually switch problems occur too.
Cheers
Post by dorsetflyer on May 13, 2005 16:03:39 GMT
Adrian, you'll probably find a lot of members have problems with these but just don't own up to the fact.
