Roy Fellingham Sussex
Guest
Post by Roy Fellingham Sussex on Jun 17, 2005 11:05:31 GMT
Has anyone thought about converting the side indicators to LCD but within the existing indicator lense?
Its a conversion I would really like to do but have no idea how to go about it not being electrically minded. However if someone knows what to do and could give me instructions I could do it.
Anyone able to offer advice?
Post by Roy Fellingham on Jun 17, 2005 11:06:56 GMT
OK Sorry I mean LED not LCD (foolish boy!)
Post by Phil Nottingham on Jun 26, 2005 21:13:13 GMT
Its a very good idea but LCD's are unidirectional and rely on the lens design to allow some sideways vison. They would look good though and the same principals would seem to apply as for the panel light conversion in the recent Take 5?
Post by dorsetflyer on Jul 1, 2005 19:01:08 GMT
I did some checking on the festoon types we need to replace the bulbs normally fitted, and unfortunately, size is the problem. We need them to be about 35mm long and 8mm dia, and at the moment they are too big. I also think that replacement ones complete would again be too big. That's not to say they might get smaller in the future. Panel lights may be different and if they would fit they would certainly light up the instrument panel better than the dismal set up at present. Sometime when I'm out browsing in the accessory shops I'll try and see what is available now.
Post by PatMcCoy on Jul 14, 2005 11:02:56 GMT
Post by Bertie on Jul 14, 2005 13:59:27 GMT
Post by dorsetflyer on Jul 15, 2005 20:49:15 GMT
Before we all go mad on replacing these lamps, I am told that they are not yet approved in the UK. If you do fit them they will attract a fail at MOT testing time. You will have to replace them with the original bulbs to pass the test. The lighting supplier 'RING' is currently awaiting for the approval so they can market them. It is hoped that approval will be given by the end of this year.
Post by Smallfry on Jul 15, 2005 23:37:49 GMT
Tut tut tut................ All these "Max Power" modifications You will all be wearing hoodies next and baseball caps the wrong way round ! A lot of cars come as standard now with LED lamps, so I dont see any problem with approval.
Post by Roy Fellingham on Sept 22, 2005 14:43:34 GMT
Its been a while and I must admit I haven't made any real progress on this subject. The thing to remember is I'm talking about the side indicators, if a few LEDs were placed within the original lenses the MOT man would probably not even notice. Plus the fact that the lenses themselves are what need to be type approved not necessarily the bulbs. Therefore brightness is the only issue here. LEDS should be fine at MOT time on that basis providing they are bright enough.
Post by Smallfry on Sept 22, 2005 23:03:28 GMT
The other problem that would need addressing is that as the LED s draw very little current, they will not "load" the flasher unit enough, and depending on what type you have, could either make the flash rate very high, or just stay on with no flash.
Just like if you have a bulb gone.
Post by Bertie on Sept 23, 2005 7:22:08 GMT
Ultraleds.co.uk can offer a replacement flasher unit or resistor for use when indicator bulbs have been replaced with LED's. Do remember that most LED's only emit light forward, not radially like a bulb does. But why re-invent the wheel? It's not like bulbs or flasher units are scarce or especially unreliable is it? Bertie
Post by Smallfry on Sept 23, 2005 16:53:36 GMT
Actually I have to agree with Bertie.............
Its not as if you are running 250 bulbs in a circuit.
Bulbs are cheap (if you buy from the right place) and reliable. You should get a box of ten for what Halfrauds charge for one !
Most problems are due to either bad earthing or your lamp assemblies being knackered. By the time you have weighed out for the LEDs and a different flasher unit, you may as well buy new lamps !
Post by Roy of the Rovers on Oct 1, 2005 11:04:05 GMT
Well its for 2 reasons. 1) I couldn't get the bulbs locally. 2) I'm bored with the car but love it, so I was considering changing all lights apart from the headlights and fogs to LED. I might even customise the lenses... the whole car will get a makeover eventually... Pimp my P5! lol
Post by lagain on Mar 8, 2006 10:09:36 GMT
No
Post by Deleted on Mar 8, 2006 10:59:42 GMT
Well, I have changed my instrument ligting bulbs for white LEDS and also changed the interior lamps festoon bulbs for the 18 row LED equivalents - brilliant! The interior lights are now very bright compared to the candle type light from the festoons - and the LEDS do not get hot to the touch either. Trouble is, I forgot to order two more for the head rest lamps - I will get some to prevent burning the top of the seats if the headrests are down when switched on accidentally!! Try ULTRALEDS.co.uk the site is amazing and the range of LED torches at very reasonable prices will be an eye opener. Cheers Adrian
Post by Phil Nottingham on Aug 28, 2008 16:14:27 GMT
This firm is still going - I have used quite a few now
Post by DaveCole on Sept 1, 2008 12:54:50 GMT
Adrian
I thought you'd sold your car!
Or did you see the light (sorry about the pun) and change your mind.
David
Post by glennr on Sept 1, 2008 13:34:28 GMT
Dave, I think Adrians posting was 2006.
Post by dorsetflyer on Sept 1, 2008 15:26:54 GMT
Post by glennr on Sept 1, 2008 15:34:43 GMT
I am awaiting a John Wallett reply....any minute now....
Post by dorsetflyer on Sept 1, 2008 15:56:26 GMT
Safe at the moment, having his tea (carrots perhaps). ;D ;D
Post by johnwp5bcoupe on Sept 1, 2008 17:20:07 GMT
Never mind Glenn, its all the same with these 'Carrot Crunchers' from Cambridgeshire their allways out of sync with the rest of us. I will give you carrot cruncher mushy peas and pies and black pudding and guys from Dorset for desert is what Geordies eat
Post by DaveCole on Sept 2, 2008 12:13:20 GMT
You really can go off people can't you! i'm going to sulk now
regards
Inbred carrot cruncher
