Post by kdh northumberland on Sept 24, 2005 15:50:12 GMT
bit daft this one, the perfect material to repair a broken courtesy light switch is a chopstick(honestly) a plastic one of course !
Post by dorsetflyer on Sept 24, 2005 18:23:46 GMT
Can you elaborate on this more fully?
keith northumberland
Guest
Post by keith northumberland on Sept 28, 2005 16:36:44 GMT
what you do is take an ivory coloured chopstick,it is nearly the right colour and the end that you hold in your hand is a round cornered rectangle,then a little filing will have it the right size to cut off to replace a broken courtesy light switch plunger
Post by dorsetflyer on Sept 28, 2005 19:49:01 GMT
I'm with you now, you are in fact referring to the door switches, not the switch on the actual courtesy light.
