Post by Phil Nottingham on Jan 1, 2006 17:43:42 GMT
8-)Spurred on by the likes of Freddy and Richard Firtpatrick's kind offer of the loan of some of the new bulbs I have shelled out an extortionate sum and changed the courtesy lights, instrument illumination, switch illumination ad clock. The improvement in general illumination is well worth it plus the nice bluish light instead of the yellowy glow as before. I have also put green leds in the Heated Rear sceen switch and gear indicator with very good effect. Furthermore I have put some in sidelights which are much more noticeable although the red pips are not as bright. I heartliy recommend these and I suggest you vist the MO website at. www.Ultraleds.co.ukPS Richard I will post yours back as soon as the post offices reopen - thanks for the demo
Post by Deleted on Feb 12, 2006 18:35:48 GMT
What size leds fit the dash and gear lever illumination? Are they screw, push or bayonet?
Dennis
Post by Phil Nottingham on Feb 12, 2006 23:13:08 GMT
The dash switch illumination & clock are BA7's (minature bayonet) single leds (5 in total) The gauges are the Edison small screw 6 led wide angle - 3 required + 4 more if Coupe The gear selector is the 39-39mm Dome (festoon) 9 leds which also fit the courtesy lights All except the Domes are polarity conscious Note that I do not think the leds in the sidelights (BA9's) show up as well in daylight (having left my sidelights on once recently) so I have put them in the number plate lights
