Post by bogbasic on Jun 5, 2006 17:52:05 GMT
Hello, I have had an intermittent problem with starting in which the car starts fine from cold but once the engine is hot,
turning the ignition switch just gives a click. This click emanates from the relay next to the fuse box.
Over the years I have replaced the inhibitor switch and adjusted it several times, I've replaced the wiring to the inhibitor switch, I've replaced the starter motor and the starter motor relay (i.e. the one that is linked to the inhibitor switch).
Anyhow the problem has been getting worse recently and I'm too scared to drive the car in case it gets stuck somewhere!! In fact I've been too scared to go to the petrol station for several years so I have to bring back petrol for the Rover in a jerry can!! Shows aren't my forte.
I thought the engine might be seizing when hot but a test wire shows that there's no current going through the brown and white wire to the starter motor and it only happens when the engine has been run till its hot. It stems from the fact that there's no current going through the red and white wire from the ignition switch when the engine has been run for some time. When its cold, a test light shows that turning the ignition switch sends a bit of current down the red and white wire but none at all when the engine has been run for some time!
What can be going wrong?? Could it be something to do with the ignition switch or the ammeter even?? The circuit diagram shows these two are connected.
I am going to replace the relay next to the fuse box since this is called the relay for the starter motor in the workshop manual (51 on circuit diagram) but it looks more like a relay for
the alternator and a phone call with Jon Wadhams today suggests thats what it is.
Anyhow if someone has the time to look into this, it would be very much appreciated.
