Post by bogbasic on Aug 13, 2006 19:20:54 GMT
Hello, a couple of times the P5B has come back from the MOT with the top left wire disconnected from the alternator relay (different garages, too). What are they up to? It causes the ammeter needle to flicker about, just like in the related topic. Any clues much appreciated!
Post by harvey on Aug 13, 2006 19:30:01 GMT
Is this after welding has been done for the MOT? If so all I can think is they disconnect this rather than the battery to protect the alternator.Don't know whether it would though. I can't think of any other legitamate reason.
Post by glennr on Aug 14, 2006 5:55:56 GMT
Might be worth asking them directly especially as they don't put it back on
Post by johnwp5bcoupe on Aug 14, 2006 8:02:30 GMT
Normally they would disconnect the battery if MIG welding to stop back EMF (spikes of high voltage/ induced current) going up the LT cable, as the battery is in the boot probably easier to pull the input to the alternator which will protect the regulator.
Post by bogbasic on Aug 14, 2006 11:40:23 GMT
Good ideas, but it didn't need welding this time - only the brakes had to be freed off!
Post by johnwp5bcoupe on Aug 14, 2006 12:38:31 GMT
Terminal connector is loose or they boost charged the battery ?
