Post by glennr on Sept 19, 2006 17:11:30 GMT
Can anybody tell me how to wire three leads to the back of the clock that has two connectors? I could find out in time but I thought I would ask you to save time! The replacement clock was working before it was removed from another P5B.
Post by Deleted on Sept 19, 2006 18:31:13 GMT
Your clock wiill have 3 connections when you think about it. 1, Permanent live feed. This will be the purple colour. 2, Negative / Earth. This is the black cable 3, The Red & White coloured cable is from the lighting circuit to illuminate the clock at night. There is normally small fly leads of the corresponding colours with lucar connectors at one end & bullet connectors at the other end to plug in to your 3 way connector shown in your photo. The one for the illumination bulb wiil have a bulb holder at one end & a bullet at the other. Hope this answers your question OK. Regards , Tony.
Post by glennr on Sept 19, 2006 18:46:09 GMT
Tony, you're a diamond. Many thanks for the answer
