Post by Warwick (Ozcoupe) on Apr 29, 2007 3:13:13 GMT
Can anyone tell me please, where the tacho wiring pick-up points normally are on a 1970 model? The tacho is reading over double the correct reading.
The car has had Luminition (optical "points") fitted and has a late model Japanese alternator so one of these is probably causing the problem. I'd like to disconnect the tacho until I resolve the problem and would like to do it the easy way for preference; that is, without removing the instrument panel.
Post by Phil Nottingham on Apr 29, 2007 8:11:33 GMT
The tacho picks up via an an ignition fed inductive loop on the back of it, another ignition fed supply is also present.
Use SEARCH se to a long time span for more info and pictures
Post by Warwick (Ozcoupe) on Apr 29, 2007 9:20:34 GMT
Thanks Phil, I'll do that.
This is the first day that I've had a chance to have a good look under the dash and under the bonnet, in detail. I found a small unhappy-looking device in a metal case, with some fried wires attached. Disconnecting it stopped the fuel gauge and temp gauges from working.
Testing it with a multimeter showed it was a straight-through connection; doing nothing.
Do these 2 gauges have a voltage-regulated feed? Is this thing a voltage regulator? If it is it would explain the high readings on both gauges.
And, why not the oil pressure gauge too?
Post by Phil Nottingham on Apr 29, 2007 10:14:22 GMT
That was the voltage regultor a standard Lucas device used on many cars of the 50-80's incl Land Rovers/Minis. Stabilised at 10volts I think
Do not use the instruments without it as they will burn out. Ensure there is no short circuit that caused the old unit to burn out before fitting a new one.
Th oil gauge works differently and is not as sensitive to voltage variations usually these under record due to hardening and eventual failure of a rubber diapragm in teh sender
Post by johnwp5bcoupe on Apr 29, 2007 10:20:20 GMT
Post by Warwick (Ozcoupe) on Apr 29, 2007 23:58:03 GMT
Thanks Phil and John; very helpful. Hopefully the gauges haven't been damaged yet.
If this is one of those bi-metallic regulators that pulses on and off, would it be okay to replace it with a modern solid-state switch-mode regulator of sufficient output?
Post by Phil Nottingham on Apr 30, 2007 16:31:10 GMT
Yes I think so
