Post by Deleted on Jul 2, 2007 9:54:31 GMT
My fuel gauge is stuck on the half full mark,should I relace the gauge first or the fuel tank sender or both ?
Any advice would be appreciated.
Post by Deleted on Jul 2, 2007 15:34:08 GMT
It is not unusual to find that the sender float spindle is locked solid. Some kind of a tool is needed to unscrew the retaining ring. See if the gauge drops by disconnecting at the tank. New senders are available.
Post by Phil Nottingham on Jul 2, 2007 16:04:44 GMT
Its best to remove the pick-up pipe first as the it can be seen if the arm is stuck - sometimes it rubs on the sides
