Post by Deleted on Jul 22, 2007 21:44:47 GMT
Can I change from right to left?
Post by Phil Nottingham on Jul 22, 2007 22:31:54 GMT
It should be possible without too much difficulty as the left/right circuits are separated so its just a matter of tracing the cables and swapping them around - I will study the diagram
Post by johnwp5bcoupe on Jul 23, 2007 6:23:12 GMT
It can be done but not as easy as just swapping a wire the park side of things is totaly seperate from the switch the nearside is hooked up with rear numberplate, boot light and illumination but it can be done the only way is to swap he feed from respective sides
Post by Deleted on Jul 26, 2007 17:38:52 GMT
It looks like I have to bite the bullet. (pun here)
Post by johnwp5bcoupe on Jul 26, 2007 21:00:58 GMT
Mind the teeth
