Post by Deleted on Jul 27, 2007 19:31:44 GMT
The rover I am doing up does not seem to have an earth strap Between the engine and the bodywork where should this be?
Post by Phil Nottingham on Jul 27, 2007 20:33:38 GMT
From o/s front subframe mount to body to engine - its 1 piece but 2 separate short ones will do the trick
Post by Deleted on Jul 27, 2007 21:24:12 GMT
thanks.
Post by p5tgc on Jul 28, 2007 18:02:15 GMT
Confirm previous response, but would add that my coupe also has an earth strap running from the back of the passenger side cylinder head to the bulkhead. Is this standard fitment, or has it been an addition?
Post by Phil Nottingham on Jul 28, 2007 19:39:13 GMT
It seems like an addition - some P5B's/Mk3's had one from the gearbox rear mounting. It does not matter as long both ends are fastened to clean metal that is not corroded, unless its a concours car
