dizzy
Sept 22, 2007 21:55:23 GMT
Post by Deleted on Sept 22, 2007 21:55:23 GMT
Hi all i am about to change from electronic back to points at the moment the dizzy has lumenition fitted is it just a mater of removing this and fitting points and a condenser will i stil need the ballast resister i have stil got the armod cable that goes to the ballast then to the coil can i do away with the ballast and run the armod cable strait to a non ballast coil then to the dizzy can any one help need car for holiday
dizzy
Sept 23, 2007 16:55:35 GMT
Post by Deleted on Sept 23, 2007 16:55:35 GMT
Why are you swapping from Lumenition back to standard points / unreliable condenser setup? I have just fitted Lumenition to my 3 litre because of points / unreliable condensers!!
dizzy
Sept 23, 2007 20:08:29 GMT
Post by Deleted on Sept 23, 2007 20:08:29 GMT
I have got a sd1 distributor with the 2 wires coming from it if i change the drive on it to the p5b type what do the 2 wires go to
dizzy
Sept 23, 2007 20:34:53 GMT
Post by johnwp5bcoupe on Sept 23, 2007 20:34:53 GMT
vince you have a problem you can't fit the drive gear from a P5b and you have the ballast resistor, amplifier missing I think? the later dizzy's have the module bolted on the side but none can be converted to fit the standard P5b oil pump, unless you fit the SD1 timing cover/oil pump
dizzy
Sept 23, 2007 20:44:11 GMT
Post by harvey on Sept 23, 2007 20:44:11 GMT
I think you'll find you can fit the P5B drive gear to the SD1 distributor, if you want to do it the other way around you have to remove a section of the tang on the distributor to get the gear to fit. Why you would ever want to fit an SD1 distributor and ignition system I wouldn't know, most of them , early ones in particular were cr*p.
dizzy
Sept 24, 2007 6:08:29 GMT
Post by johnwp5bcoupe on Sept 24, 2007 6:08:29 GMT
The problem is with the shaft on the SD1 harvey it is too short because of this there is no tang If you have a lathe and a miller it could be done or I should say I could knock up an adapter
dizzy
Sept 24, 2007 11:33:49 GMT
Post by harvey on Sept 24, 2007 11:33:49 GMT
The problem is with the shaft on the SD1 harvey it is too short because of this there is no tang If you have a lathe and a miller it could be done or I should say I could knock up an adapter No tang eh? Who needs an oil pump drive anyway, you blokes are just perfectionists! ;D
dizzy
Sept 24, 2007 12:05:44 GMT
Post by johnwp5bcoupe on Sept 24, 2007 12:05:44 GMT
What do you need oil pressure for anyway harvey
