Post by Deleted on Sept 23, 2007 13:48:32 GMT
Hi all how do you do the basic lamp test when doing the timing where is it you cornect the lamp to
Post by Deleted on Sept 23, 2007 18:00:15 GMT
If you disconnect the coil lead from the coil then it is just a circuit tester that you need to see or hear when the contacts open. The buzzer types are best but you can make one with a bulb and battery.
Post by johnwp5bcoupe on Sept 23, 2007 18:45:10 GMT
If you haven't got a meter use a 12v low wattage bulb with a holder one wire to the Contact Breakers and the other to 12v supply fuse 1-2 on the strip will do there is a spare spade terminal ! if you are worried use a 5 amp fuse and holder in the +ve side.
Post by Deleted on Sept 23, 2007 20:00:16 GMT
Thank you for help Have you got a wiring diagram for connecting a coil for electronic and points i have got the armed cabal and wire from starter for 12 volt to start car
Post by johnwp5bcoupe on Sept 23, 2007 20:13:50 GMT
You will have to explain a little more vince what sort of electronic ignition I have emailed you the wiring diagram
Post by Deleted on Sept 23, 2007 22:45:47 GMT
Hi it is a lumenition but i think it has stop working that is why i need a wiring diagram for electronic and points so i can try both i checked my email but knot had one yet thanks for your help
Post by johnwp5bcoupe on Sept 24, 2007 6:20:30 GMT
I have emailed
