Post by Deleted on Sept 30, 2007 19:48:45 GMT
sorry, but new to this...
how do i operate the light switch correctly - sidelights, main, full beam and fogs? oh, and flicking the panel light switch one way gets them on, what does flicking it the other way do??
just got the car and no nothing!
Post by eightofthem (Andy) on Sept 30, 2007 20:37:13 GMT
What you need is an owners manual full of all the things you need to get you going they are available through the club light switch as follows switch in central all off switch at right side/ tail+side lights on switch at left side /park lights on drivers side only for headlights on place light switch to right side and move the stork that is behind the indicator stork downward. while in this position the pedal that looks like a footrest next to the brake is your full beam switch push down for on push down again for off . if you want fog lights to the front on, place light stork to the up position leave the switch to the right and next to cigar lighter there is a pull on/off switch thats the one for front fogs.
