Post by Deleted on Jul 24, 2008 15:43:04 GMT
Hi After a day spent in the engine changing filters and re tuning the carbs, spark plugs etc. i took it for a test run and noticed the temp guage does not move at all, thought maybe the car was just being nice to me but after leaving it sitting running for a while the guage still did not move off of 0. So now i am wondering what is possibly wrong as it worked before i started work on it. was wondering if maybe i knocked something? Advise needed as i miss driving my car, too worried to get in it now Many Thanks Em
Post by Phil Nottingham on Jul 24, 2008 17:06:04 GMT
You could easily have dislodged the sender cable which is near the engine end of the top rad hose. its Lucar conneor and correcdes or the cable breaks which may not be obviuos at first glance. You may need to replace the Lucar. It may be the sender or wiring and this can be quickly checked but try the connection first
Post by Deleted on Jul 25, 2008 13:12:22 GMT
thanks you , that's what it was. The car now running ok, not frightened to drive it now. i had dislodged the cable.
Thanks again Em
Post by Phil Nottingham on Jul 25, 2008 18:38:33 GMT
If only everything were so simple.................
