Post by mcgill on Jul 26, 2008 14:06:37 GMT
could anyone inform me what is that that black gunky stuff called used to fill gaps in the body work like the bottom of the a bc d pillars where they meet the sill............or can i use silicom? thank you........
Post by PatMcCoy on Jul 26, 2008 16:14:25 GMT
DumDum
Post by mcgill on Jul 26, 2008 16:22:13 GMT
thank you pat
Post by dorsetflyer on Jul 26, 2008 16:48:27 GMT
It's available from Frosts, or JRWadhams.
Post by Warwick on Jul 27, 2008 13:12:09 GMT
That wasn't very nice Pat!
Post by johnwp5bcoupe on Jul 27, 2008 14:23:44 GMT
could anyone inform me what is that that black gunky stuff called used to fill gaps in the body work like the bottom of the a bc d pillars where they meet the sill............or can i use silicom? thank you........ Where are you filling with DumDum All the joints where the posts meet the sills are welded/leaded. DumDum used around the screens, rain channels trims etc where you want a water seal.
Post by Phil Nottingham on Jul 27, 2008 16:41:46 GMT
Quite correct John. DumDum is the useal stuff for windwo rubbers etc and sealing removeable plates but nowadays black silicon is actually better as it does not run under heat. Not advisable to use this for windows though
Post by mcgill on Jul 30, 2008 15:24:04 GMT
i knew dum dum was used for the windows,but this stuff i pulled from the interior side of the bottom of all pillars and posts.......and a bit near seams on top of a posts......ohhh i didnt realise it ran in the heat...so am i better off with the sillycon ?
Post by johnwp5bcoupe on Jul 30, 2008 15:50:53 GMT
i knew dum dum was used for the windows,but this stuff i pulled from the interior side of the bottom of all pillars and posts.......and a bit near seams on top of a posts......ohhh i didnt realise it ran in the heat...so am i better off with the sillycon ? DumDum doesn't run when hot so I don't know what Gumph you have and why it is where it is There should be a load under the rain channel
Post by Phil Nottingham on Jul 30, 2008 16:17:12 GMT
The DumDUm I used recently a new big tin of it does run in the heat!
Post by johnwp5bcoupe on Jul 30, 2008 17:39:35 GMT
That's very strange Phil I have just done the two coupe screens etc etc in this heat in full sun and mine didn't run it gets sticky but that's about it I used 5 small tins and there is a difference sometimes between tins
Post by Phil Nottingham on Jul 30, 2008 18:58:34 GMT
Well mines a large tin so it will last a long time! I think silicon is better on bodywork as the DumDum does harden and fall off or look as if its sealing and its not!
Post by johnwp5bcoupe on Jul 30, 2008 21:07:51 GMT
I haven't used silicone Phil allways reluctant, I know what it does to paintwork when you are doing a respray and if you use anti silicone drops all you are adding is silicone and you NEVER get rid of it
Post by Warwick on Jul 31, 2008 0:05:15 GMT
I presume DumDum is just a brand name for what we call black mastic; a windscreen sealant that came in a tube. It doesn't go hard for years.
Post by johnwp5bcoupe on Jul 31, 2008 5:59:32 GMT
I presume DumDum is just a brand name for what we call black mastik; a windscreen sealant that came in a tube. It doesn't go hard for years. No Warwick not the same as window sealer you can use your hands to put this stuff in hasn't really changed in 50 years or so?
Post by Phil Nottingham on Jul 31, 2008 16:25:19 GMT
Quite correct - and I have not found a like substitute either. Its not as fluid as windscreen mastic although looks very much like it - not as sticky either
miguel
Post by miguel on Jul 31, 2008 17:38:13 GMT
Post by Phil Nottingham on Jul 31, 2008 18:42:54 GMT
Yes that the one & only
