Post by glennr on Aug 15, 2008 18:14:02 GMT
Hi all. Got a slight problem. (nowt to do with a recent visit to the doctors) I have a problem with my o/s/r sidelight. Bulb is ok but I have no power for the sidelight? brake light is ok though. O/s front sidelight is ok. I recently got the handbrake light to work so may I have disturbed something under the dash?
Post by johnwp5bcoupe on Aug 15, 2008 18:23:44 GMT
Glenn it's a case of trace the red wire as long as the front is working it must be either a bad connection a wire out a bullet connector, corroded socket if you get stuck bring it over
Post by glennr on Aug 15, 2008 18:34:11 GMT
Cheers John Boy. I will investigate further.
Post by glennr on Aug 16, 2008 17:33:29 GMT
Sorted
Post by johnwp5bcoupe on Aug 16, 2008 17:54:11 GMT
Post by glennr on Aug 16, 2008 18:38:41 GMT
Sorry, should have said. :PJust a dodgy bullet connector. Many thanks. Just got to sort out the rear brakes. One moment they are slightly binding the next they are OK. Might help to take her for a drive but she now needs her MOT. Going in Monday.
Post by johnwp5bcoupe on Aug 16, 2008 19:45:07 GMT
Check the two nuts on the rear cylinders Glenn they should allow the cylinder to float they shouldn't be tight my old girl had her test this week as well
Post by Phil Nottingham on Aug 16, 2008 21:34:55 GMT
Obviously not used much!
Try SEARCH
Post by glennr on Aug 17, 2008 5:34:14 GMT
Obviously not used much! Try SEARCH A bit difficult Phil. I can't use it for work as I am an A.D.I , so Sunday/Monday is normally my day off but I have just worked 10 days on the trot with little chance of getting out for a drive. Stroll on retirement.
