miguel
Post by miguel on Aug 27, 2008 17:17:32 GMT
I´ve tryed to remove the rear lights, but the 4 bolts that holds the unit to the wing dont want to get out. They start well but then all of them become more and more difficult to turn, till they stop. Is this rust or a special technic?
Post by Phil Nottingham on Aug 27, 2008 18:15:01 GMT
Screw them back in and coat threads frpm inside of wing with penetrating oil (Plusgas is best) let soak for a few hours and then try unscrewing - you may have to repeat the process a few times.
A good, tight hollow ground screwdriver is essential. Behind them will be another plate held in by equally rusty self-tappers - grind them off if necessary
