Post by PatMcCoy on Aug 27, 2008 22:50:38 GMT
Has anyone found the festoon bulbs used as Side indicators in led bulbs
Post by Keith - Portsmouth on Aug 27, 2008 23:32:22 GMT
Post by Phil Nottingham on Aug 28, 2008 16:15:21 GMT
This firm is still active and has widened its range considerably
Post by Warwick on Aug 29, 2008 5:41:17 GMT
Or for anyone in Australia, try Keith Simpson at the LED Shop On-line. I've bought lots of stuff from him for all sorts of applications. www.ledshoponline.com/
Post by johnwp5bcoupe on Aug 29, 2008 9:41:50 GMT
My concern would be for the flasher unit as the smaller current drawn will effect it to the point it may not work if you change all the bulbs to LED's
Post by Phil Nottingham on Aug 29, 2008 17:13:34 GMT
You are quite correct John - the old standard clicker flashers and earlier ones will not work. The firm did stock special electronic flashers that do work.
Note also these leds unless suitably protected are very volatge sensitive an dcannot cope with voltage spikes - a faulty alternator, dynamo or even the courtesy dealy unit I fitted will blow them
