Post by Deleted on Sept 3, 2008 20:49:29 GMT
have replaced the old mechanical pump with an electrical facet pump. know sod all about electrics, so now I'm running it of the rear window heater switch, and I'd like some advice as to how to synchronise it to the ignition.
Post by johnwp5bcoupe on Sept 3, 2008 20:56:55 GMT
Look at the fuse block for the IGN feed and pick up the supply, use a seperate fuse to feed your pump
Post by Deleted on Sept 3, 2008 21:06:44 GMT
thank you very much
