Post by eisdielenbiker on Sept 27, 2008 19:34:27 GMT
Hi, i would like to replace this marked material with new one. Have you any idea where and under what name i can source some ? Thanks Mark
Post by johnwp5bcoupe on Sept 27, 2008 21:23:43 GMT
The material is Moquette and available from Woolies Some cars have the Moquette stuck on to the metal direct others like mine have a shaped hardboard panel which is covered and screwed to the metal. www.woolies-trim.co.uk/c-106-moquette.aspx
miguel
Post by miguel on Sept 27, 2008 21:51:20 GMT
Moquette? then what´s this?
Post by johnwp5bcoupe on Sept 28, 2008 6:25:41 GMT
The tunnel cover is wool carpet but not the type you can get today Miguel so we have to use a substitute
Post by Deleted on Sept 28, 2008 17:31:47 GMT
ive redone both on my car with replacements from wadhams. have to say i was very happy with the results.
Post by johnwp5bcoupe on Sept 28, 2008 18:18:15 GMT
Neither is a problem to replace it's a case of using your old material as a pattern you only need a trim supplier why pay through the nose
miguel
Post by miguel on Sept 28, 2008 19:22:12 GMT
Very cheap!
Post by eisdielenbiker on Sept 29, 2008 7:43:22 GMT
Thanks for helping. I have another question after visiting the Woolies site: What colour of vinyl do you recommend to match Buckskin ? I want to make up a trimmed cover for my parcel shelf mounted seat belts. Mark
Post by johnwp5bcoupe on Sept 29, 2008 11:34:29 GMT
Post by Phil Nottingham on Oct 9, 2008 16:23:33 GMT
The trim is also known as Furtex and Fluxflex when used asthe door draught excluder
