Post by Steve Vine on Nov 22, 2008 17:05:52 GMT
Hi All, I have recently purchased a a 1965 P5, and it has the white/yellow number plates. I have been trying to find a replacement back to Black with with raised or silver plates. Front no problem, but the rear one is causing a problem. Could anyone help with finding a company that will make up both plates to the correct size. Steve.
Post by johnwp5bcoupe on Nov 22, 2008 17:35:59 GMT
The rear will not be easy if you want it shaped as per original you will have to find a one that has been used with standard plate or fill in the holes and respray have a word with David Green green.david10@sky.com there is some old posts on this subject
Post by Steve Vine on Nov 23, 2008 17:31:31 GMT
Thanks John, I will give David a call.
Post by Eric R on Nov 30, 2008 22:17:34 GMT
JRW provides close match number plates - try pl8s.co.uk/ who made up mine so will be aware of the style
Post by Deleted on Dec 1, 2008 7:53:59 GMT
I wouldn't bother with the Wadhams "close match" backing plate, it's rubbish and poorly made.It doesn't even have the beaded edge. Get an original from one of David Greens scrap cars and restore it yourself, it's easy to do. You will then have a proper pre-drilled heavy duty aluminium plate ready to fit in the boot recess and you can then add your made up B&W plates to it. I stuck mine on and posted some images last year and there was a full discussion about the subject at that time.
Post by Colin McA on Dec 2, 2008 18:16:32 GMT
I am having a set of plates made up by steve Frampton.
Which reminds me that I need to phone him to see if it is ready yet. Friendly guy to deal.
Last I heard JRW was out of stock as I asked steve to see I he could source the plate from him.
Colin
