Post by eisdielenbiker on Dec 17, 2008 20:41:19 GMT
Recently I fitted a self-adhesive plastic chrome strip. It might sit a little too low doesnt it? But considering that the sills still need better welding one day they are ok for now. Mark
Post by Phil Nottingham on Dec 17, 2008 22:07:18 GMT
Actually if it had been fitted at the proper height it would have looked quite authentic - the sills are supposed to be satin black below it though.
This is another topic on which there is aealth of information and pictures tomsee
Post by glennr on Dec 18, 2008 6:36:32 GMT
Not bad, but Phil and yourself are quite right. The sill trim is far too low. If you want I can send you the info sheet that I enclose when I sell the s/s sill trims. Please feel free to P.M me.
Post by johnwp5bcoupe on Dec 18, 2008 9:42:42 GMT
I think you mean the coachline eisdielenbiker? yes it's a little low should be the same height as the top of the 3500 badge I can see why you didn't paint the sills yet eisdielenbiker something less glossy and black may hide a few things untill you get the welder out, at least you found enough metal to fix the trims somwhere well done the car is looking good
Post by eisdielenbiker on Dec 18, 2008 14:26:26 GMT
Thanks for the input and ideas. I don't worry about the coachlines but about the sill trim position. I hope that Glenn would give some more information in a PM. Satin black paint is a good and easy starting point next spring. The sill is just patch welded below the rear door.
Post by johnwp5bcoupe on Dec 18, 2008 20:03:44 GMT
I have it now Mark you have plastic sill trims I got there in the end
Post by dorsetflyer on Dec 18, 2008 20:13:46 GMT
Post by johnwp5bcoupe on Dec 18, 2008 21:55:38 GMT
I think we can forgive him this time as he does suffer the occaisonal 'senior moment' Now then John it's just my brain not connecting plastic trim to a P5 sorry about the pun oops another moment
